KPG-D6
JLFH
PVR, MEX
My Windows 10 failed and had to use the OEM restore feature to get Windows back, but now my KPG-D6 doesn't take the license key as a valid one, any idea how can I make it work?
Josh
Auburn Hills, Michigan
In this situation (I was in the same boat about a year ago) You're out of luck. In my case I had a computer failure and was unable to boot the machine's HDD and disable the old license. This new era of licensing really sucks in many ways, except for the manufacturer-- in their case they ensure that pirated software is abated.
If you have the original license key for the software, Kenwood can manually kill it in their server and release it so you can reinstall it on your computer.
This is some info I got from Evans (KD4EFM on this site) a while back on how to handle a hard drive/motherboard type failure:
Anyone who has a REGULAR COPY OF THE SOFTWARE, please make a note on what your machine ID is;
Open License management Client, go to SETUP, GENERAL, DEVICE ID. Click on copy, and save it to a text file where you can
pull it up should there EVER be a pc/laptop/HDD failure. This will be needed to send to Kenwood Tech Support.
You will also need the copy of your ORIGINAL EMAIL WITH THE LICENSE KEY.
In the event you have a hard drive or motherboard failure, contact your dealer that you purchased the software from.
They will contact KWD_TS with your information, to begin the license refresh. There is NO DEADLINE TIME ON THIS
PROCESS!
JLFH
PVR, MEX
I show this thread to my dealer, but it's a no go, where can I contact Kenwood support to try to get the license reactivated?
PROCESS!
Start here:
kd4efm
Florida
IF your dealer said they do not want to help you, Look up their UPLINE and complain to them.
This process does take some time, but it is do-able.
You could call kenwood, but they 90% prefer your dealer to be making that call.
You will need your ID from the LMC handy and on hand when you do call.
LMC; SETUP/GENERAL/DEVICE ID
save it.
Next, the KPG_D6 Key, you should have gotten a txt file with the KEY ID in hex and or the ID itself,
You will need to provide that information also.
desciption.txt should have been with the email sent to you by your dealer.
ARE YOU IN MEXICO??
Not sure how Kenwood Central America does things.
So this may be indeed, a tough cookie to bite, but you might have to purchase another key to
get past the long process of getting it rebooted (reset).
