LA County UHF narrow?
AM909
Radio/computer geek
SoCal
Is there a good, hopefully ongoing, source for which LA county channels remain wideband (i.e., nominal 25 kHz channel spacing, 5 kHz dev)? Is our page currently accurate?
ecps92
Taxachusetts
Only a true insider will know if the T-Band channels went narrowband on an agency by agency basis
Altho UHF was required as was UHF-T, as the dates got closer T-Band was exempted
yet many agencies had already obtained $$ to touch each radio, others decided to wait it out.
So, the answer is YMMV but for programming a Scanner, see what sounds best for your ears.
prcguy
Next week I can measure the deviation of several LASD transmissions and tell if they are wide or narrow band.
AM909
Radio/computer geek
SoCal
It can be difficult to measure, either with a service monitor or by ear, for a couple of reasons. One is that many of the SCC dispatchers just don't speak up. I see peak deviation of less than 1 kHz from some of them. Hard to tell if 1 kHz is 40% of 2.5 kHz or 20% of 5 kHz (or 25% of 4 kHz). :) The mobiles can be better, but it can take a while to find traffic on channels that repeat them or be close enough to hear them on the dispatch input. We know the numbered dispatch and L-TACs are all narrow – it's more about the other TACs, parks, TSB, tunnels, MA, custody, etc.
prcguy
Yes I know it can take awhile and I would monitor both base and mobile to determine deviation. Too bad an LASD friend of mine retired, I could have measured his radio with my service monitor or possibly pulled the code plug to see how its programmed.
pewpew45
I could be wrong, but I believe the department switched out all the dispatch, l-tac, a-tac repeaters a couple years ago and also switched all those frequencies to narrowband.
It won't matter soon anyways, the whole department will be on the trunked system soon enough.
Engine104
Member since 2005
Winnetka, CA
Right, and a lot will be encrypted, including L-Tacs and A-Tacs :(
lenk911
St Paul, MN
Regarding: " It can be difficult to measure, either with a service monitor or by ear, for a couple of reasons. One is that many of the SCC dispatchers just don't speak up. I see peak deviation of less than 1 kHz from some of them. Hard to tell if 1 kHz is 40% of 2.5 kHz or 20% of 5 kHz (or 25% of 4 kHz)."
Cant you just measure the deviation of the tone/code during voices pauses? 0.7-1 KHZ = wide band and 1/2 that narrowband?
