>> The newer GRE scanners, IIRC, are capable of programming NAC codes to prevent picking up other systems that operate in analog mode on the same frequency
Actually, GRE didn't have to enable the PSR 500 and 600 to actually decode the specific NAC code to enable the scanners to discern analog from digital. The Uniden 996 does that by being able to set a conventional channel as "digital."
The real advantage of being able to select the NAC code is that some digital channels are used with multiple NAC codes. For instance, at those airports where TSA communications are digital, you're likely to find more than 1 NAC in use on 172.900 MHz. Each NAC represents a different usage for the same frequency. TSA radio users using NAC code "A" won't hear users using NAC code "B" ... and visa versa, unless someone is in scan mode.
Bottom line is to not assume that only one NAC code is in use on a digital conventional channel.
