Lapd rampart
marvjenk
North hollywood ca
You prob wont with a rubber antenna from North Hollywood. Outdoor scanner antenna will.
I get it fine with my outdoor Antenna from West Valley - SFV
Thank i test it out when I go to that area next week to see if that it but a received central div great.
FrensicPic
Los Angeles
I receive Rampart 506.9375 adequately here in the West SFV. My BCD996P2 shows 2 "bars" and audio quality is good and clear.
The antenna is an old Radio Shack VHF (high) 1/4 wave ground plane on the roof at about 20 feet off the ground.
Paco-Jerte
You Member, Member!
34.0500° N, 118.2500° W
central is no problem. You prob cant hear 77th st, Harbor, West LA, Southwest, Wilshire right?
Outdoor antenna is the best way, I use a a Discone and get all of LAPD including all tacs and simplex.
My scanners are SDS100 TRX-1 and Tapped 2006/2042 that work great with all LAPD using the Discone from Chatsworth
Navy9545
Los Angeles
Paco-Jerte,
A comment and a couple of questions, if I may. I too have a SDS100 with an Antennacraft ST2 about 25 feet up with approximately 50 feet of RG-11 coax. I live in the East SFV, however, I do not get near the reception you get with your discone antenna. My reception for South Bureau is spotty and West Bureau is non existent. What kind of a discone antenna do you have and at what elevation? Thank you in advance.
Paco-Jerte
You Member, Member!
Paco-Jerte,
my antenna is an old Radio shack Discone using RG-X8 cable and its about the same height as yours. I also have the same Antennacraft ST2 at my 2nd home and works fine with most LAPD in the LA area.
Many factors could be blocking your signal. Building, trees, Power Lines, and of course Hills. You might want to fine tune the ST2 until you hit the sweet spot. Take your SDS100 to the roof and use a short cox cable and move your antenna until reception gets better on the hard to tuned stations.
Navy9545
Los Angeles
Thank you and yes unfortunately I do have some obstacles, but I will get up there and give fine tuning a try.
