Latest Mobile Pictures...
K
kb0nly
Guest
Here is the latest pictures of the mobile setup.
1997 Pontiac Trans Sport
Yaesu FT-8900R
XM Satellite Radio
Horizon Navigation Navmate 2.0 GPS
Comet SB-15 Tri-Band Antenna
Active GPS antenna, the hockey puck on the roof rack.
XM antenna, the small mag mount puck near the center of the roof.
The radio is remote mounted in the back so the body is near the antenna, makes for a short coax run and less stuff in the way up front.
The control head is mounted above on the roof console and the mic is connected by an extension cable and surface mount jack box that i fabricated to put it down within reach.
All power connections are handled in the lower center compartment which has been turned into a power center. Relay's turn all added equipment on and off with the ignition and all equipment is powered from a fuse panel which is fed by a 4awg feed from the battery and fused under hood with a manual trip and reset breaker so everything can be disabled with one button if necessary. The 4awg feed was leftover from my previous install which made use of 100w Motorola X9000's so i just left it, leaves room for further expansion without having to replace it in the future if more current was needed.
Also added was two DC power ports on the right hand side of the center console, this was needed for the kids DVD player on vacation trips and plugging in the laptop and cell phones, etc.. Might as well get it out of the way while i was doing everything else. The only connections to the vehicles wiring is a fused tap from the fusebox for the ignition switched feed that controls the relays, using the stereo fuse, and the 4awg feed to the battery. I like to leave the vehicle wiring as untouched as possible. And the GPS system is tied into the VSS, Vehicle Speed Sensor and Backup light circuit, which allows it to navigate using its internal gyro without a GPS lock if necessary. The XM is interfaced through a FM modulator that is inline with the vehicles antenna, turn it on you have XM, turn it off you have local FM. Also on the right side of the center console is an amplified Motorola speaker for the 8900.
The 8900 does dual duty, on the right side of the display i generally have the ham band frequencies displayed, and on the right side i scan and monitor PS frequencies, which eliminates the need for a scanner and give it an overall cleaner and uncluttered look and feel.
The picture of the control head shows the mic plugged in before it was moved during testing, just in case your wondering.
K
kb0nly
Guest
In the picture showing the Motorola speaker.. That black cable on the floor is gone, that used to be a scanner antenna connection to a glass mount antenna that no longer exists and has been removed.
Now i just need to get the carpet cleaned! The dirt one tracks in.. Not to mention the kids!
Almost forgot to mention, the GPS computer is under the passenger side seat. And i guess the XM antenna wasn't on the roof at the time these pictures were taken. Its in the center of the roof near the GPS antenna.
K
kb0nly
Guest
Thanks!
I am picky about wiring, always have been. And my customers appreciate that when i install a radio or computer.
K
kb0nly
Guest
That's called a Tapa Fuse and it's available from my bud's at Waytek Wire, www.waytekwire.com They make them for both the regular ATC and the Mini ATC like my van has. It's one handy little bugger. A lot better than using those brass taps that will just end up bending out the fingers in the fuse panel.
Item # 46065 is the regular size
Item # 46044 is the mini size
They are not cheap, $8.67 each, but i really feel its worth it to keep from damaging an expensive fuse panel. I would rather pay that much for the fuse tap than cut into wires or damage the fuse panel and have to repair/replace anything else!
They also carry circuit breakers that go in place of a normal blade type fuse, i have been thinking about switching over to them in place of the fuses in my added panel. They are a manual reset push button. Just search their website for ATC and you will find them. You can also request or download a catalog, lots of good stuff for your next electrical project.
K
kb0nly
Guest
Boy not around here, i checked every parts chain we have and couldn't find them. I got a Waytek catalog in the mail about a year ago and that was the first time i ever saw those.
