LCN order
Markef
Missouri City,TX
When you program the PRO 528 do you have to start on channel 1 and do you skip the blank channels on a system or must you program 000.000 in the blank channel ? The 528 does not want to follow the system correctly.
RoninJoliet
ILL
The LCN on LTR systems usually appears in the ID ex: 0-10-200, the "10" is the LCN or "home channel " of the freqy. You would put that freqy in CH10 of the scanner in any bank and mark it LTR....Most LTR systems are listed on rr.com and there home channel sequence is labeled...
