Led Alarms and Alerts
cbro298
Greenville SC
I am trying to modify my alarms and alerts on my scanners .( 106-500-197) I backloaded the scanner to Winn500 and cannot seem to figure it out.I tried to do it manually and seem to have the same issue.Any help or suggestions will be helpful.
Cortese
Westmoreland County, PA
Connect to Win_500 and bring up control screen. Go to tab "TSYS Objects". Click on the specific alpha group that you want to identify with the colored LED / alarm. It should highlight the whole row. Over on the right mid way down screen you will find the drop down boxes for LED / alarm settings. Make your selection(s). Top of screen click on "scanner" and the drop down option will appear. The select "upload to scanner".
Macomb, Michigan
Wirelessly posted (BlackBerry8330/4.3.0 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/104)
For the 106 try this for the alarm. Press the PGM key, now press the down or up arrow key to your desired talkgroup. Now press the F2 edit key,then press the F2 CURR key,now press the right arrow until get to the correct scanlist,you will know this when an "*" asterick appears next to it. Now press the down arrow key to Alarm: Now press the right arrow key to your desired alarm. Press the F1 Save key. Hope this helps. I believe this will work for the 197 and 500 maybe
