NS9710
I was curious if they operated by radio, and if anyone knew their frequency? I see they have the antenna on them, but that's about all I know
I'm only seeing two fixed sites (locations) both in Emporia on that license and no class MOI (mobile-itinerant) frequencies so the answer is noWould those frequencies be used statewide? I forgot to mention I am in Petersburg, VA
-------------I'm only seeing two fixed sites (locations) both in Emporia on that license and no class MOI (mobile-itinerant) frequencies so the answer is no
Where are you seeing PL info?-------------
151.0025/155.7825 mhz, (I) pl 131.8 & 155.3850 simplex base simplex...probably also 131.8 hz. pl. LifeStar is a favorite customer of the Virginia Dept. of Corrections.
Already done & it isn't listed for this particular licenseeIn order to determine whether or not the licensee is authorized for "statewide" operation, select "Locations". If the display lists "Statewide", it will state such as example just shown. Otherwise, it is not for a "Statewide" operation.
Incorrect. The correct answer is "Yes". Read carefully (WPRR647). Lifestar Ambulance Service has is authorized up to 15 mobiles: (O) 151.0025/155.7825 mhz., (I) pl 131.8 & 155.3850 simplex base simplex...probably also 131.8 hz. pl. LifeStar is a favorite customer of the Virginia Dept. of Corrections.
In order to determine whether or not the licensee is authorized for "statewide" operation, select "Locations". If the display lists "Statewide", it will state such as example just shown. Otherwise, it is not for a "Statewide" operation. A different location(s) will display for LifeStar's area of operation. In this case, "Lifestar Ambulance Service" is authorized to operate within a 25 mile LOS area of Emporia, VA. To convert kilometers to miles, multiply 5/6 x the km value in this case "25" . It will get you close to the actual mileage distance. If you forgot your 6th grade math classes regarding using fractions, sorry I can't help you there. The audio emission type(s) for this license is "11K2F3E" = Analog, "11K2F2D" = Digital. Obviously, the "Digital" option can be ignored. However, often multiple audio emissions are authorized depending upon also being licensed for others baselines, i.e., (DMR)MOTOTRBO, NXDN/NEXEDGE, Phase 1, and Phase 2.
----------I'm not seeing where Whiskey3JMC's statement is incorrect. In other words, I'm not seeing evidence that LifeStar's system is capable of statewide communication. In order to have statewide communication, there would need to be a statewide network of repeaters. The license doesn't show that.
