Linked capacity plus not working
rtempleton
Harrisonburg, VA
John, thanks so much for your offer of help! I will definitely take you up on it.
The first thing I did was update to the latest firmware
Set up my static WAN
Set up the bridged LAN
Set up my Port Forwarding with Hairpin NAT rules. (This is where I'll need help)
System consists of 2 Sites located on the same campus
2 SLR5700 repeaters at each site
I have 2 MikroTik RB750GR3 that I will be lab testing with. We may deploy these at the installation, or perhaps use a pair of RB2011IL-RM.
Thanks again, look forward to speaking with you!
Firebuff880
Boynton Beach, FL
Read this first ---
https://cwh050.blogspot.com/2012/10/mototrbo-and-ip.html
rtempleton
Harrisonburg, VA
Thanks Firebuff880. I have been watching Wayne's tutorials and reading his blog posts every chance I get for a couple of weeks now.
Project25_MASTR
TX-COMU
Texas
Seeing as to how your sites are on located on CAN (if I read correctly) I would suggest setting up an EoIP tunnel between the two Tik’s IP addresses on the CAN network (their static IPs) assuming they are pingable from one another. This will eliminate the need for port forwarding to get the sites to communicate with one another. It is essentially equivalent to having a really long piece of UTP between the two WAN poets on the routers.
If you give me some time I will provide and example of which I am currently using for Connect Plus sites and remote monitoring of Capacity Plus sites using Mikrotik RB450Gs.
rtempleton
Harrisonburg, VA
MCore25, thanks for your comment and I look forward to learning more about this option. Yes, I believe it would be considered a CAN and the static IPs set aside for the 2 routers should be pingable.
Currently there are already 2 pairs of IPSC repeaters on both sites that will be replaced by the new Capacity Plus Multisite configuration.
Project25_MASTR
TX-COMU
Texas
Here is my example of my setup.
My two Connect Plus sites are gatewayed to the internet via T1 connections (with static IPs from my ISP). For your application, imagine my WAN connection is your CAN connection. I will provide commands via the CLI but if you played any with Winbox you can figure out this structure under the GUI.
1.) Assign a static IP to the the interface you use to use on the CAN. Example:
Code:
ip address add address=1.0.1.1/24 interface=ether1
2.) Assign gateway in the route menu. Example:
Code:
ip route add dst-address=0.0.0.0/0 gateway=1.0.1.254
At this point, you should be able to ping the other router's CAN address (if it is setup).
3.) Assign IP to LAN port (I typically only use one on my setups and mostly ignore bridging or master/slave status since I use switches at all of my sites). I tend to stick with Motorola's Astro 25 IP addressing scheme where the second octet represents zone, third site, and fourth the device. So for my "legacy sites" i.e. Capacity Plus I use a zone of 0...Connect Plus is currently zone 1. Example:
Code:
ip address add address=10.1.1.254/24 interface=ether2
I think you are already mostly to this point...I wouldn't bother with DHCP for now but here's the skinny on setting up EoIP. You will need both IP addresses on the CAN at this point I'm assuming one is 1.0.1.1 and the other is 1.0.2.5.
4.) Create EoIP tunnel. Example:
Code:
interface eoip add name=eoip1 remote-address=1.0.2.5 tunnel-id=10
The name can be whatever you'd like (I name my end geographically) but tunnel ID has to match on both ends (think of it like a VLAN). If you are using a T1, you may have to adjust your MTU but that's a trial and error process. The other site will need the recoprical for name and remote address.
5.) Add IP to EoIP (which is now an interface). This can be a /30 as it will be a virtual ethernet cable to the next router. Example:
Code:
ip address add address=192.168.0.1/30 interface=eoip1
As you can see the interface is literally the name you gave to the EoIP tunnel on the router.
6.) Add route to complete it all. Example:
Code:
ip route add dst-address=10.1.2.0/24 gateway=192.168.0.2
Let me explain if you aren't too familiar with Layer 3 routing. Destination address is the network you wish to reach and the gateway is the gateway IP of the route. So 10.1.2.0/24 is the network of site 2 and gateway is the IP of the device on the other router. Note, if you add a third site and you wish to continue with static routes, you will always use the next router over as the gateway but change the network. Example for building a route to "Site 3" that has to go be repeated through site 2 from site 1:
Code:
ip route add dst-address=10.1.3.0/24 gateway=192.168.1.2
At this point, you should be able to ping individual devices connected to the LAN port from the other site. LCP will now function entirely on the Layer 3 level behind the firewall. If you need to have remote management, you will either need to open a port on a site router (or both) or create another "maintenance" site (add another router) that is in your NOC (for me that's my office). You can configure your firewall as required on your routers.
Pittsboro IN
Mcore25 - what firmware version are you using?
I had an EOIP tunnel between my home and office that was up for over a year, then went away during an upgrade from 6.2 something to whatever was next.
Normis and his gang could not tell me what happened.
Project25_MASTR
TX-COMU
Texas
I use whatever the current stable release is and upgrade once every few months. I found some issues with trying to do it via Router OS’s dynamic DNS service though (pings work going to the static IP but you can’t ping the locals behind the dynamic IP).
Right now I think it’s 6.43.x
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
I would like to add that RSSI roaming thresholds are very important in LCP. Change them to -95 or -90 to make the system work better for portables..... TT
