Listen to radio while charging?
bosco836
I apologize if this has been asked before; however, the site appeared to time out when attempting to use the search function.
I recently acquired a Kenwood 2207 VHF Portable with a KNB-29N Ni-MH battery. Will I damage and/or reduce the capacity of the battery if I listen to the radio while it is charging?
Many thanks,
- Bosco
bosco836
Thanks. I thought I had read somewhere that charging the radio while listening to it can cause damage, but perhaps I was mistaken.
bosco836
Sorry if this seems like a stupid question - but - why would transmitting while charging be an issue if MURS was programmed in?
Would the same issue still apply when transmitting on frequencies other than MURS?
C138NC
Tactical Taco Consumer
NC Taco Command
PSorry I wasn't clear on that. I meant since Its a vhf, you can have the 5 unlicensed frees programmed In and or If your a ham op. You could have the club repeater on it. Just saying tx while charging puts strain on the battery and the other end who's rx'ing will only hear a hissing or noise I cant describe.
Also It goes for any radio, vhf, uhf, 800. If anyone has a better analogy.
K8TEK
Banned
Ohio
You could have said don't transmit while charging. People do use radios for more then MURS and ham radio club repeaters.
