LMRN Technical Data Discussion
w3rwn
The tenants at the Collingwood Grain Terminal have been given notice to vacate the property so that's out of the question.
Keep in mind that this is only meant to cover Wasaga Beach not any other municipalities since they don't have the crowds that Wasaga does.
Does Collingwood have a new BEAT repeater on 700 MHz yet?
I see the old one in the database on BEAT01 / 413.5375 so maybe it will be 772.13125
32dave
Oxford County, Ontario Canada
So there is a fatal wreck in the top end of the county as of writing this and shortly after OPP showed up this patch happened. Any ideas ?
gary123
I see Oxford often patched with Perth 19040. On FleetNet, Oxford was often patched with Norfolk. If it is Norfolk, it will be TG 19036. If you restart DSD it should show the patched TG when it first decodes the site.
gary123
last night there was a bit of inversion and I was in a position to do some logging from Western Ont. Here is what I captured.
site primary CC
3 142.650
4 142.320
5 142.605
6 142.950
7 142.800
8 142.590
9 143.070
11 142.380
12 142.410
13 142.880
15 142.320
21 142.530
22 142.245
23 142.590
25 142.965
27 142.590
28 142.905
31 142.310
32 142.725
33 132.830
36 143.070
37 142.230
44 142.800
45 142.935
46 142.260
detailed site capture
3
142.650p, 142.050s, 142.815s 141.450v, 142.845v
Neighbor 4, 5, 7, 9, 12. 15, 21, 23, 33
4
142.320p, 142.230s, 142.575v, 142.785v
Neighbor 3, 8, 12, 25, 33, 36, 44, 45
5
142.605p, 142.245s, 142.455, 143.985
Neighbor 3, 6, 7, 9, 12, 13, 15, 23, 39, 44, 47
6
142.950p, 142.725s, 142.080v, 142.440v, 143.190v
Neighbor 5, 26, 34, 39, 41,44,47
12
142.410p, 142.710s, 142.170v, 141.975v
Neighbor 3 ,4, 5, 7. 9, 23
13
142.545p, 142.095s, 142.695v
Neighbor 5, 7, 9, 11, 15, 37, 40, 46, 47, 147
21
142.530p, 142.260s, 141.300s, 142.110v, 143.640v
Neighbor 3, 18, 22, 23, 32, 33, 45
36
143.070p, 142.350s 142.200v
Neighbor 4, 8, 25, 44, 45
VA3DBJ
Ontario Database Admin
The Whitby tower has a patched Supergroup: TG=19111, which I believe we have down as Aurora OPP at the moment.
So 19111/19112 are active on the LmRN Whitby tower now. Toronto and Whitby are still on FleetNet. So it looks like only Aurora switched today. I figure GTA will be done before next week. They must have just switched, cause there are a lot of reg's and de-reg's happing.
I am wondering if:
19111 old 1OPS38 (Aurora 5A and 5B)
19112 old 1OPS46 (Aurora 5L - 407)
exkalibur
York, Ontario
On the new system, there won't be a Toronto and Whitby, as they merged a long time ago.
I haven't heard a peep from 1OPS38 on FleetNet so that would likely ring true about them switching, along with Highway 407 (which I would agree is the 19112 group, assuming 19111 is Aurora).
VA3DBJ
142.050 has been added to the Whitby tower and 2510 has appeared for MTO-E. Assuming Toronto.
142.830 seems to have been removed, but might be a temp thing, as 142.23 is flashing as both CC and scc.
The Whitby tower just went offline.
EDIT: It pops up for a few seconds, every now and again. So they are definitely playing with it.
Muxlow
Super Secret
Middlesex County
Group 5354 is tagged as Aurora District for MNR. I'm not sure if that's accurate or not. I've had that same group active for the past month + off the Chatham site as they have a MNR office there. (Seen it a few times on Essex, and about 3 transmissions off Sarnia) It's either some wide area group or something specific.
Just wanted to toss that out there.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I'd guess it's a wide area OPS group like the old OPS channels. SSM Dispatch used to pop up on OPS03 on Fleetnet so I would assume it's the same. I've logged over 5000 transmissions on it and just over 100 on 5355.
exkalibur
York, Ontario
5354 is extremely active on the Toronto and King City sites. Much like the old 1NRO03 group, I suspect it covers a very large area. I used to hear COs in Niagara, London and up north in the Barrie area on there.
Muxlow
Super Secret
Middlesex County
Always active off the Chatham site daily, but very rare Essex or Lambton
I have it tagged as MNR OPS02
Muxlow
Super Secret
Middlesex County
Group 2506. MTO Enforcement of some sort but not sure on a location.
Seeing it patched with Essex MTO and Lambton OPP off the Sarnia site
Anyone else have any hits on 2506? Seems the Enforcement groups follow a even number pattern
2500 London
2502 Wellington
2504 Essex
2506 ??
2508 ??
2510 Toronto
and so on and on. My guess would be 2500 London Ops and 2501 London Tac. 2502 Wellington Ops 2503 Wellington Tac and so on
Just curious if anyone else has 2506 on their logs and what site it was seen on to try and figure out a general area
(Checked on the 36 and 44 sites and don't see it patched with them. 19039 and 2502 are patched off the site 44
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Maybe Elgin or Oxford or even Kitchener for 2506 and 2508
Seeing OPP talkgroups out of detachment range: 19490, 19619 off of Toronto 147.
Muxlow
Super Secret
Middlesex County
I figured it would go by the truck inspection stations. Essex having 1, Lambton, Middlesex. But that won't work out too good since Lambton MTO is always on the Essex talkgroup (same on FleetNet too) Middlesex officers would just cover Elgin as the Essex guys do Chatham-Kent
Have to get lucky someday and get a MTO officer to roll through their radio.
VA3DBJ
A new channel (142.3350) appeared on the Whitby tower at lunch, as a voice channel. Still no secondary control channel assigned yet.
With MOH north and south, OPP Toronto and Aurora, MTO Toronto and Durham and MOF all active at noon, they pushed it to the 3rd frequency. :)
