Mobilman44
- Joined
- Apr 15, 2018
- Messages
- 98
Hi,
While I regularly use my Uniden sds200, I've recently got the bug to hook up my Cobra CB and make it into a base station.
So I set it up with a Radio Shack power supply and hooked up a standard magnetic base car antenna to it. Well, the results were dismal.
The unit is in my hobby room on the second floor of a two story here on the outskirts of Houston. The majority of any CB traffic would be on I-45, which is 2 miles east of me. Obviously the antenna has its work cut out for it.
Anyway, I then strung up the antenna on an attic rafter, and of course the reception was better, but not good at all.
I did some rookie research and found a Firestick IBA5, which may do a much better job. But they run about $120 and I hate to spend that money if there is only minimal improvement.
So obviously, I'm looking for advice/comments from you all, and I thank you in advance!
