3MTA344
In regards to the lower squelch helping P25 decoding, hell I noticed that with my old BC250D back when the Phoenix digital system was first being tested! On my trusty old BC796D, the squelch is set all the way wide open. Works pretty good that way, too.
Here in Phoenix where we have the RWC (which stands for Simulcast Radio System from Hell ) the best solution to this problem has been to put up a Yagi antenna and position it so that signals are only coming from ONE site. Once you do that, it comes in very very well. Not quite perfect, but considering the fact that you can buy a decent Yagi for less than 50 or build one yourself for less than 20, good enough.
If you want mobile use, set up your scanner on a yagi anyway, and become a feed provider so you can listen to your scanner anywhere you have cell service on your smartphone. :twisted:
-AZ
Hi AZScaner: I have some answers and a permanent fix for this issue. You will have to P/M for it. Its a great fix and you will learn a lot but worth it. Let me know. I heard AZ has had problems with their Simulcast issues. It will be a fun project for you to take on unless you already are happy with your yagi antenna work around.
