Lost Display on Pro-2096
bfpdb
Carlisle, Ar
My 2096 has lost its display again, this is second time, was repaired under warranty, anyone had this problem? unit works fine but is usless without any display info.
DaveIN
Founders Curmudgen
West Michigan
True, check the LCD contrast adjustment first. Then I would look at the flex cable connection, it could be loose.
Bucko
Marietta, Ohio
The 2096 does not use the same display, the 2055 is smaller and supports more characters. If out of warranty I would check the ribbon plug in like DaveIN suggested.
