My PSR-600 has started receiving random frequencies. After a second or two, there is a loud beep from the speaker and the audio cuts off. It does this continuously. Any ideas?
Are you using it with the factory power supply? Do you notice any dimming in the backlight and/or display when it exhibits this behavior? Sometimes a failing power supply can cause erratic behavior.
Yes it is the original equipment. No, there are no other symptoms. I turned the scanner off overnight and have not had the problem since. We'll see if it comes back after another few days of constant operation.
Dave, I am not sure of the construction of your scanner so please forgive if not a good suggestion. Is it possible there are two PCB's connected by pins inside the scanner? If so, one or a couple pins may be tarnished. If separated and reconnected it may be just enough to permit 100% continuety. Just a thought. Lets hope it is already cleared of it's issue but if it happens again, think about it (also, might be a good idea to check for any loose plugs if present inside?).
