jhq0123 said:To prcguy: thanks much for the info. if I could get voice, not tones, it would work well for me.
To SAR2401: I got the info here.
RNM (remote neural monitoring) requires decoding the resonance frequency of each specific brain area. That frequency is then modulated in order to impose information in that specific brain area. The frequency to which the various brain areas respond varies from 3 Hz to 50 Hz. Only NSA Signals Intelligence modulates signals in this frequency band.
jhq0123 said:To SAR2401: I got the info here.
prcguy said:If you get the equipment to upconvert sub audible frequencies to audible your not going to hear any voices. Human voice has a band width of up to several thousand cycles per second and even a narrow whimpering mumble is probably a few hundred cycles wide. You can’t modulate any of this onto a center frequency of just a few cycles per second. What you can hear is slight changes in some of the body’s inner workings and the only thing I am familiar with uses a direct connection to your body. Good luck with your adventure.
prcguy
jhq0123 said:I didn't file the lawsuit. I just got the info.
Thanks for the info. You have saved me some research and $.
jhq0123 said:
