LPE-200
GM
From my experience, it means you have too many talkgroups programmed into the radio. You may have a limit of 128 or 255 talkgroups for the entire radio for something like that to happen. Try taking out a few talkgroups (either below the 128 or 255 limit) and see if that appears again.
harryshute
Edmonton, Alberta, CANADA
I'm having the same issue with a Scan LPE 200. Features says it allows SYSGRP# 16 and TRKSYS:255.
There were 14 14 channel systems in it when I got at. Now I have 5 systems in it with no more than 16 groups per system. It shows INV SYS all four of the five systems. The first system scans just fine. Should I try cutting the systems back to 14 groups?
Radioman96p71
SYSGRP is counted quite strictly.
14 systems with 14 conventional channels would be 14 SYSGRP and 14 CNVCHN
10 trunked systems with 20 groups would be (10x20)+10 or 210 SYSGRP
Your 5 systems with 16 groups would be (5x16)+5 which is 85 SYSGRP
The only way you will stay under the limit is a single system of 15 groups. Very limited to say the least.
That is from the documentation in RPM, they go on to explain how CNVCHN and TRKSYS are calculated as well.
harryshute
Thanks Radioman for the fomula. You are so right. If I smile at it nicely I can get 16 groups in one system. I've never seen an LPE 200 with so little space.
