LTR Passport
clisp
Is there anyway i can make this work , after reading WIKI , theres no scanner that works with passport system
however i was able to get a few ID's with my scanner by simply hanging onto a freq ...
i have a BCD396T Uniden
Any suggestions would be greatly appreciated
Thank you again
WayneH
Forums Veteran
Super Moderator
Your master site
Whatever you received with the 396 will be wrong. The error check (pass/fail) is very poor so it's possible you were getting misconstrued data.
If you want to monitor - and properly trunk - a PassPort system you need to run the LTRTrunk software. There are no other ways around it.
