M1225 Programing
Is there a way to program the M1225 without a RIB? or do I absolutely have to have it?
Thanks.
jim202
New Orleans region
Thanks.
You can make your own level translator. It is not that hard. But the bottom line is you can not connect the radio directly to your serial port on your computer.
Plus I believe that the software will only run under a true DOS computer. In other words, you need to boot a slow computer directly into DOS and not run the program inside a Windows DOS pane.
davidgcet
1225 is windows based, but won't work on newer machines very well. i've had it work on XP, never tried vista or 7, but heard it can be flaky.
I have the last version of it running on XP on a 1.6 single core seems to be operating ok, I can edit archive files its just its just not seeing the radio and tells me to check the RIB and connections.
OK - thanks for the help.
Of course it does help to have the correct cable ..... I got it programed thanks for the help all.
