M7100ip VHF intermittent ERR=0612 Code
kerrickt
Hello I have an intermittent issue with my M7100ip VHF P25 radio. My set up has the HHCH radio will work fine then sometimes when turned on will do selftest then control head display is dark after a min it will try to restart then pop up ERR=0612 code any ideas. I have did connected the control cable at the radio and reconnected no joy.
merlin
DN32su
Hmm, service manual says check the interface ribbon connection, That is located behind the front cover.
2 torx T10(?) screws and fold the front down.
merlin
DN32su
ERR=0612 is not min the radio code list, so likely a code for the control head.
I will have to dig up the service manual for that to see whats up.
radioman2001
New York North Carolina and all points in between
Loss of control head firmware or corruption, or head ID conflict. I have a fix some where as we used to get it a lot with our dual heads in our revenue cars. I believe you have to reload the head firmware to fix it, but we never had it intermittant they would just throw the code and not work until reprogrammed.
The fix used to posted on Google Groups for Orion radios.
merlin
DN32su
Thanks for that. I have a HHCU for Orion that seems near dead. I'll have to look up th fix.
PS: might be an interface cable issue.
