MAA status?
troymail
Silent Key
I was away for a few days but since being back I've noticed the MAA system signal strength is either very weak or just plain gone. My radio seems to be sensing power on the CC freq but not enough to lock in.
Those of you close to the tower - any change noted?
Have they cut the power way back or taken the thing down?
bear105
I am still hearing the new Tower quite well. No change from last week. TG28 has been active today with more comms testing.
troymail
Silent Key
Well I've said for a long time I must be in a "hole"... Whereabouts in Howard County are you..???
I have a signal again this afternoon - weak as usual... but at least it's back.
troymail
Silent Key
wadeless28 said:
That didn't take that long, to get your Thorazine and electric shock therapy worked out. :lol: :lol:
I'm sorry. I just had to go there. You know me.
Mike
Yeah - technology has sped up the process of electro-shock therapy treatments :lol: but don't try to drive right afterwards...:D
Hey Mike - can you hear this system????
bear105
I am about I-95 and Rt. 32. I guess I get 4-5 bars in the BCD996T...Outside antenna, of course.
troymail
Silent Key
Ah - outside antenna - huge difference - I'm using a 396 with a RS 800Mhz handleheld antenna....
I've been wanting to put up an outside antenna but I'm hesitant because of the grounding needs etc. Don't want to blow anything up in a thunderstorm... got any pointers to help me get past that?
TinEar
Glen Burnie, Maryland
Either buy a grounding rod and some copper wire to attach to the antenna mast - OR - if you have cable or satellite TV service, they no doubt installed a grounding block somewhere on the outside of the house. Run a grounding wire to that same block from your antenna mast - OR - all I do is disconnect the coax from the multicoupler when a storm is in the area. That won't stop the antenna from being hit by lightning but at least it won't destroy your radio(s).
Alan
wadeless28
Severn, Maryland
LoL Those medical advancements are incredible. LoL
About the new system, it's not clear from my QTH. I'm thinking there is somesort of interference between us and the airport.
Mike
maus92
The OP
Using my 396 with a rubber 800Mhz Antenex on southbound I-97, I lose the MAA/BWI TRS at the MD 3 exit.
CA
Annapolis
