Mag One/BPR40 (RVN5081D) CPS OS Compatibility
CChamblee25
I've been programming Mag Ones for a couple of years with my trusty Windows 10 laptop. It came time to upgrade my laptop, so I bought another one with Windows 11 Pro. I installed all of my various CPS, including Astro, APXCPS, Professional Series, Commercial Series, and both MotoTrbo R16 and 2.0. All of these work fine with my new Windows 11 laptop. Then came time for the Mag One CPS. First, I had to install it (v2.05) AS ADMINISTRATOR, due to several files failing to install in non-administrator mode. After installation, I attempted to read one of my BPR40's using the same cable (FTDI chipset USB). I get communication error. I reseated the USB cable, shutdown and relaunched the CPS and tried again. Same error. Device Manager shows the USB serial port on COM2, and shows that it has the most recent drivers. Tried a different BPR40 radio. Same error. I then installed version 1.02 of the Mag One CPS. Same issue, can't read radio. I've even tried all of the possible compatibility modes, including Windows 8, Windows 7 and Windows XP. No difference. Has anyone else successfully read/written from a Mag One using Windows 11 Pro?
Tech21
You probably need to manually download the latest windows 11 drivers for that cable. Windows driver manager tends to be quite finicky with these things sometimes.
com501
The standard cable for a BPR40 is a serial cable. The BPR40d comes as a USB with serial driver interface which will NOT work with the BPR40.
If you have a BPR40 cable that is USB (never seen you at this shop from Motorola) then a driver issue is common. ALL Motorola programs should be installed as an Admin and ALL should be run with user as Admin privileges. Windows 11 is strict about unsigned drivers, and many companies (including Motorola) are not paying the exhorbitant fees that Microsloth is charging companies to sign drivers.
