manual call up of any frequency
n1cyn
Taunton, MA
I'm trying to decide on a new scanner. I am replacing a Pro-95. I'm interested in the psr-700. My question is can you manually call up a specific frequency from your scan list or do you have let it scan to it then pause it. I'm thinking that the way the keyboard is set up you can't.
Thanks, Joe
VE6RHS
Chetwynd, BC Canada
On the '700 or '800 you CANNOT directly enter a random frequency.
You have to program it in using the software, find it by a search, or find it using the Spectrum Sweeper function.
This is the primary reason I keep my PSR-500 handy....
buddrousa
You can manually pick a channel as per manual page 27 in pro-107 pro-18 also works aswell.
Working with Objects
Browsing Objects
1. Press MENU until the Main Menu is displayed.
2. Scroll to Browse Objects and press >.
3. Press ^ or v to scroll through the playlists.
4. Press < and > to review the objects in each playlist.
Playing (Scanning) Objects
You can play a single object or scan all objects in enabled playlists.
You can also pause iSCAN on a single object while it is scanning.
To play objects while browsing:
1. Browse to the object you want to play by following the steps for
&#8220;Browsing Objects&#8221; above.
2. Press play/II/SEL to play the selected object.
Press play/II/SEL again to scan all objects in enabled playlists.
To scan all active objects in enabled playlists:
1. Press MENU to display the Main Menu.
2. Scroll to Play, then press play or play/II/SEL to begin playing
