Marine HPE. file Wiki for HP-1
QwKiE
Warren, Michigan
The Marine HPE file in Wiki has 1 mistake there is two channel 67,s 156.425000 should be changed to channel 68. And a question for this HPE file can the USCG helo and aircraft channels be added to this file as they are used for the same areas as far as water ways. Just wondering if it's possible.
phask
KZZV - SE Ohio
Just use Sentinel and add the helo channels to your copy...
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If you would make the fix, then zip (compress) it up and send it to me at ka3jjz1 (at) verizon (dot) net, I'll update the file in the library, if you don't know how to do it.
Thanks for bringing this up...best regards..Mike
QwKiE
Warren, Michigan
if you look
USCG is part of the Marine freqs but the helo and aircraft use more channels than just 16 emergency in the Marine set up. Would be nice to have all the aircraft and helo freqs in there so you dont have to listen to some of them on a sang channel. When something is happining in the water you want everything pertaining to that on your lock in, not all the millitary freqs to. It would not be hard for a HPE to be set up with all the pertaining freqs other than just boats. An example of that the other night two people were reported jumping in the water by the Blue Water bridge everyone was out there at 2 am in the morining looking but you heard boats but very little helo b/c there on many freqs talking this search was on for over 6 hours and you just did not hear helos in the conversation much at all. because of the freqs that are not in the HPE file. If someone knows the freqs would you please set up a HPE file with them in it
