MB Hydro
Bigun
I know Manitoba Hydro is using DMR Tier 3 system. Pretty sure they are single frequency multi-site systems. I'm only getting brief odd snippets of conversations. Signal is strong, only a few miles from the repeater.
I am using an Anytone 868 radio set to Digital monitor, Timeslot 2, any Color Code and any TG.
Am I doing something wrong? Any one listening to this system?
mciupa
Canadian DB Admin
Moderator
I'm here a lot
There are no Channel ID's listed at all for any site. Perhaps those need to be filled in properly.
Bigun
Thanks, not much info on this system, I'll look into channel id's. Pretty sure it's single channel repeaters, just not sure if a single channel Tier 3 system can be monitored with a Tier 2 radio. Hopefully someone local can chime in.
jets1961
Bigun,
Try tuning the system using an RTL first. I tried once and got some decode (poor) but never played with it much. I think I did not have a VHF antenna for my RTL at the time, I do now and I might try again soon.
But try RTL to gather info first.
jets1961
I tried to get MB Hydro going on DSD+, but the listing does not seem correct on this site, or I don't get a CC anyway. Anyone have success running MB with DSD+? What is the CC in the Winnipeg area?
Does Tier 3 DMR have a CC or just data when channel active? I read on Tier DMR in meantime.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I had no issues tracking MB Hydro from the Winnipeg site using DSDPlus. I think the control channel was 164.460MHz? I had to adjust the channel numbers to work with my Uniden scanner of course.
While I was out there working, I made a few corrections as someone had submitted the inputs as repeater outputs. I can verify the Grunthal, Winnipeg, Portage La Prairie and Neepawa sites were all working last last year.
There's a power plant just north of Winnipeg which seems to have a single channel site that isn't linked to the system.
jets1961
I will try again at home tonight, I'm at work and it's a metal building so I may be deaf on VHF here.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I believe the Winnipeg site is at the main MB Hydro headquarters. Can't remember the street name but it might have been Pembina?
ve4ear
Winnipeg, MB
Here is some info extracted from DSD+ that I have collected. on MB Hydro. It is a Tait DMR 3 system.
Here are the sites I have logged
Type/System ID/Site ID/Label
TIII, 2, 1.2, "Winnipeg-South"
TIII, 2, 2.1, "Winnipeg-South"
TIII, 2, 3.1, "Portage la Prairie"
TIII, 2, 4.1, "Pinkerton Lake"
TIII, 2, 5.1, "Darlingford"
TIII, 2, 6.1, "Morden"
TIII, 2, 7.1, "Letellier"
TIII, 2, 8.1, "Grunthal"
TIII, 2, 10.1, "Telford"
TIII, 2, 11.1, "Gull Lake"
TIII, 2, 12.1, "Seven Sisters"
TIII, 2, 15.1, "Bissett"
TIII, 2, 16.1, "Teulon"
TIII, 2, 20.1, "Beaver Creek"
TIII, 2, 21.1, "Fishewr Branch"
TIII, 2, 27.1, "Brandon"
TIII, 2, 30.1, "Neepawa"
TIII, 2, 77.1, "Riel Converter"
TIII, 2, 79.1, "Rosser"
Here are the frequencies to go with the above sites
Of importance are the channel numbers. For example in the list Below, read the data as
TIII, 2, 2.1, 343, 164.460, 169.000, 0 System ID=2, Site ID=2.1, Slot 1 CH=343, RPT out=164.460
TIII, 2, 2.1, 344, 164.460, 169.000, 0 System ID=2, Site ID=2.1, Slot 2 CH=344, RPT out=164.460
; Manitoba Hydro
TIII, 2, 1.2, 4, 169.950, 169.000, 0
TIII, 2, 1.2, 9, 170.100, 169.000, 0
TIII, 2, 1.2, 10, 170.100, 169.000, 0
TIII, 2, 1.2, 19, 170.370, 169.000, 0
TIII, 2, 1.2, 20, 170.370, 169.000, 0
TIII, 2, 2.1, 565, 163.440, 169.000, 0
TIII, 2, 2.1, 566, 163.440, 169.000, 0
TIII, 2, 2.1, 645, 165.300, 169.000, 0
TIII, 2, 2.1, 646, 165.300, 169.000, 0
TIII, 2, 4.1, 0, 170.100, 169.000, 0
TIII, 2, 8.1, 31, 162.120, 169.000, 0
TIII, 2, 8.1, 32, 162.120, 169.000, 0
TIII, 2, 8.1, 725, 164.430, 169.000, 0
TIII, 2, 8.1, 726, 164.430, 169.000, 0
TIII, 2, 10.1, 15, 170.190, 169.000, 0
TIII, 2, 11.1, 16, 170.190, 169.000, 0
TIII, 2, 11.1, 575, 163.695, 169.000, 0
TIII, 2, 11.1, 576, 163.695, 169.000, 0
TIII, 2, 12.1, 0, 170.250, 169.000, 0
TIII, 2, 12.1, 14, 0, 169.000, 0
TIII, 2, 16.1, 591, 164.340, 169.000, 0
TIII, 2, 16.1, 592, 164.340, 169.000, 0
TIII, 2, 30.1, 0, 170.040, 169.000, 0
TIII, 2, 77.1, 581, 163.740, 169.000, 0
TIII, 2, 77.1, 582, 163.740, 169.000, 0
jets1961
I'm totally deaf for Hydro at work but when I get home I'll give it a try. I did make good progress and was getting traffic but my frequencies file was set incorrect, thanks Ed.
jets1961
Is there much voice traffic on this system, or do I have to wait for bad weather?
What are IPI calls on this system is that GPS? If so can I get LRRP going?
Which file in DSD+ do I put the site names in?
