MD380 and TRBOwest
bears3312
camas wa
I have dmr md 380 uhf 400 I put trbowest connect on mine sounds great I'm I post to put md tools on it gos green help
bears3312
camas wa
that's quite correct. My md-380 will simplex on both time slots. My xpr7550 will communicate with the md-380, but will receive it on either time slot... :wink:
i have a little problem it tell me my id unknown can some help me please
thanks bears3312 ps it about connect trobowest
bears3312
camas wa
hi guys I'm new DMR I have trbowest its in radio refence database I have its tell me id unkown
please help?
thanks bears3312 ps I have md 380 400/480 uhf model
bharvey2
please help?
You should start a new thread for this topic. You question is inclined to get lost in this subject. Also, you wouldn't want to be accused of hijacking a thread. Furthermore, your question is a bit unclear. It'd be best to reword it so that the problem you're having is better understood. I, and a number of people on this forum have MD380s so you should have no trouble getting the help you're looking for.
bears3312
camas wa
dmr radio
hi guys I'm new to dmr I'm have trouble understanding some thing my radio says id unknown is a anther way fix it
thanks bears3312 trbowest wa/ore/id/
DotNM
Watchung, New Jersey
i need some can some one get me in right derction md 380 radio saying id unknown
thanksbeard3312
When do you get this "Radio ID Unknown" message and where do you see it? Is it in your programming software or on the radio itself? If on the radio, when does it happen (for example, only when you press the PTT?)
jonwienke
More Info Coming Soon!
VA
If you want to TX on the TRBOWest system, you must get an ID from the system admins first. If you don't have a good reason to do so, you shouldn't even try.
bharvey2
As was stated, TRBOWest is not an amateur system but a commercial one. You need permission and an ID from them. It might also be trunked system in which case an MD380 won't work. Assuming you have an HAM license, why not try Pacific Northwest DMR?
kayn1n32008
ØÆSØ
Sector 001
Trbowest is a Motorola proprietary network. Your MD-380 will not work properly on it.
If you are wanting to transmit on that system, you need to get in touch with the system owners, and pay them to gain access to it. You WILL require a Motorola radio, capable of Connect Plus trunking, to be able to transmit on that system.
If you have not asked for permission, and have not been given an ID that has been provisioned by the system owners, you need to stop.
