MDC-1200 ID on XPR3500e
JackRoberts23
Hey all, how do I display the ID of the transmitting radio on a Motorola XPR3500e? I went to the signaling tab and all in the CPS, and can't seem to find it
hakwye8518
Town of Islip, NY
In the channel screen where you enter tx/rx frequencies under rx settings select your mdc system from the signaling system drop down.
hakwye8518
Town of Islip, NY
yes it will display the id of the transmitting radio, if you want to have a name come up instead of a hexadecimal number go to contacts then mdc and then add a private call contact and enter in the mdc id and rename it to whatever name you would like displayed. For instance instead of having id 10 show up on the screen you can create a contact and have id 10 show up as dispatch on the screen
JackRoberts23
Ok perfect. Yea I know how to change the ID and stuff from HT radios but I couldn’t figure out how to display the ID on the XPR. Thanks all
JackRoberts23
Ok it's working except when I want to add the name of AMBULANCE 349 for the ID of 0349, (that is the correct id) it reverts to 349. Is that normal?
K2NEC
NA
349=0349=0000349
The amount of 0's in front is doesn't matter, it's still 349
