K2KOH
Silent Key
Thanks to everyone who chimed in on this one. I appreciate the assistance!
Listening to the problems, it sounds to me that the mic plug itself is problematic. Those 4 conductor plugs are just too small for four connections to be soldered and they break with the slightest misuse. I have replaced several for my grandson's xbox mic/headset combo. they use the same type of 4 conductor plug. You will need steady hands and a magnifying lamp.Thanks to everyone who chimed in on this one. I appreciate the assistance!
These are the best I've found: Three X 3.5 mm 1/8 inch 4 Pole Conductor 3 Ring Audio TRRS Plug Male Adapter USA | eBay
Be sure the wires are in the correct place![]()
I really hope it's one unit issue. I'm telling you, I am hooked on this rigI'd send it in too, maybe it's a one unit issue, but if it's more widespread, the sooner they start knowing about it the better. Besides, warranty work is always better than attempting a fix yourself.
Michigan?! Who is doing their warranty work? (Unless the moved from Washington.)Spoke to Icom today...had a nice chat with the service tech. He seems to think the same thing I do, so she's off to Michigan tomorrow. I don't want to play around much with the microphone or the jack since the radio is only a month and being the clumsy oaf I ma I would probably do more harm than good.![]()
In my case it turned out to be the plug on the mic. It didn’t appear damaged in any way. Looked fine, but the connection was very intermittent. HRO was happy to swap the mic and everything works perfectly now.My IC-705 is about 24 hours old. I tried to key up for the first time tonight and no Tx. The other buttons on the mic work, and the speaker on the mic works.
If I press firmly on the 2.5mm plug to push it into the radio, I can Tx, but without pressure on the plug, I cannot.
I purchased it from the wonderful folks at HRO Anaheim yesterday (unfortunately about 45 min away). I’ll need to get up there this weekend. Hopefully it’s the plug and not the jack.
