TerryPavlick
Wallingford PA Villas NJ
1040- Angry21 on 339.725 established W107, also hearing a/a 319.174
319.175 and also 240.250 in the clear.
Picking up Have Quick comms as well 235.050 252.925 271.950 314.450 308.750
Activity on 283.525 also loud and clear - mentioned local altimeter setting - calling a COLT flight......sounds like a ground station at a range
Okay unconfirmed but perhaps 283.525 is range control at R4006 - anyone ?
Okay another update on 283.525 - in talking to the aircraft the controller said to contact tower and report mother in sight.....so maybe a carrier off the coast. That frequency shows tied to the USS Ford which is off the coast of Virginia
paradiver
Middle River, MD
I was planning to fly at N07 this weekend but then the 2 TFRs over Bedminster and MMU popped up. I'm assuming it's going to be Trump landing in a C-32 (since it came yesterday for the familiarization flight) but does anyone have any specific times for his arrival or departure? And what (if there are any) fighters will be protecting the TFR? (also if anyone has any freqs that would be cool)
You can track AF1 usually on adsb exchange and on VHF frequencies. for KPHL I have seen them exit SFRA in PALEO or GRACO gates direction to over the Eastern Shore of Md and then north.
Either you can hear them with the scanner or I attached the Live ATC sites. Also attached is the ZDC Sector Map
KADW
KDOV
KPHL
ZDC: Washington (ZDC) Air Route Traffic Control Center Scanner Frequencies and Radio Frequency Reference
  • ZDC Sector Map.pdf
AirScan
Caught what I believe was JUMBO70 with a frequency ending in xxx.9000 going overhead here in VT.
Probably 238.900 which is AR212 primary. At the time they were on AR212 fueling with MAINE 85. They generally use VHF with ATC on those AR routes, if you monitor Boston on 135.700 you should be able to hear them get their AR clearances onto AR212/AR204. LiveATC Audio
Just curious if you were able to hear anything from the 2 VT ANG F-35s KNIGHT 11-12 that were working in Viper around the same time, they were using 314.400 for A-A, with brief contacts on 226.300 (Viper Common), 244.500 (Range Control), and 293.700 (OPS).
JetWash
Fairfax, VA
NOTAMS posted today that will interest to those in the Oceana NAS area:
CLASS D AND E4 AIRSPACE CLOSED TO NON PARTICAPATING AIRCRAFT FOR AN F-18 FLIGHT DEMONSTRATION,SFC-15,000' AGL MON 24/MAR 1500-1600L . NO OUTBOUND TAXI FOR TAKE-OFF AFTER 1450L, NO DEPARTURES AFTER 1455L, AND ALL ARRIVING AIRCRAFT MUST BE ON DECK NO LATER THAN 1453L TO ALLOW TIME FOR TAXI AND TO ENSURE STERILE AIRSPACE.
Same info…same times…for March 26.
Can you post the link?
Looks like 09-0017 will be AF1 for the KMMU-KPHL trip Saturday evening as POTUS travels to the NCAA Wrestling championship.
2025-03-20 16:27:01 AE4AEA 09-0017 B752 AES:AE4AEA GES : D0 2 ..90017 QUARINCXA~1FPL AVAILABLE FLIGHT PLAN A0285 (KMMU - KPHL) FOR TAIL 90017 IS AVAILABLE FOR RECALL
2025-03-20 16:27:01AE4AEA09-0017B752AES:AE4AEA GES : D0 2 ..90017 QUARINCXA~1FPL AVAILABLE FLIGHT PLAN A0285 (KMMU - KPHL) FOR TAIL 90017 IS AVAILABLE FOR RECALL
Also has flight plan from PHL to ADW
2025-03-20 19:30:06AE4AEA09-0017B752AES:AE4AEA GES : D0 2 ..90017 QUARINCXA~1FPL AVAILABLE FLIGHT PLAN A0286 (KPHL - KADW) FOR TAIL 90017 IS AVAILABLE FOR RECALL
