Migrating KPG Software to New Computer
wradar
I finally got a new-to-me (used) CF-53 with Win10 and took all the files from my old programming laptop (WinXP), put them on a thumb drive, and moved them to the new laptop. Unfotunately, when I open any of the Kenwood KPG programs (-38D, -44D, -95D, etc.), I get errors along the lines of "A correct License ID has must be registered. Reinstall the programming software."
Unfortuntely, I've had these software for years, and I have no idea where the original CDs or whatever media they came from went.
Any tips on how to migrate the software from an old radio to a new one without the original disks?
EWC_BDN
do you have the keys? I would recommend finding the software elsewhere online and downloading it. it's not even piracy because you have the keys. maybe that stuff's still on the dealer portal and a dealer could download them for you and email the installer .exe files. it might be too old though.
personally i would just google those softwares and find get em.
wtp
Port Charlotte FL
if you still and the original hard drive, how about getting one of those external drive things and hook it up that way ?
kd4efm
EL98 Florida
From the old laptop, re-edit to the Kenwood FPU line, and you will find your keys there, write them down.
That way you install on the new laptop those key ID. (LID)
THE NEW STUFF, D-x, you want to unathenticate, and then export those out to a thumb drive to load in to your new LMC.
wradar
Yes, but I have no idea where they are. Clearly they're associated with the installations on the old laptop, since they all work, but I don't know where the keys are kept or how to find them in order to fully reinstall them on the new computer.
AM909
Radio/computer geek
SoCal
I found relevant registry keys for the older (i.e. not KPG-Dn) stuff at "HKLM\SOFTWARE\WOW6432Node\KENWOOD Corporation\" that record your license key. Other than just looking there for the LID value, you might be able to just copy the registry keys. For example, with KPG-89D:
  1. From a command-line on the "old" machine: REG EXPORT "HKLM\SOFTWARE\WOW6432Node\KENWOOD Corporation\KPG-89D" KPG-89D.reg.
  2. Copy KPG-89D.reg to the "new machine" and do: REG IMPORT KPG-89D.reg .
If it doesn't work after that, you'll probably need to reinstall from the installer (get as suggested above) and then use the key found in the LID value in the file exported above (i.e., TYPE KPG-89D.reg to see it).
The correct procedure for moving the later KPG-Dn stuff is discussed elsewhere.
I'm going to need to build a new machine soon, too, hopefully before the other one dies, though I'm reminded that we (hopefully) have dutifully recorded the relevant keys here. :)
