military air frequency's am or fm
jerk
jerkville
Also would like to know what to set Fort Jackson (Richland county SC) trunk system to far as if its a LTR UHF or VHF or a EDACS system
And the same for Shaw AFB sumpter SC
You'll need a digital scanner for the trunked system.
Try these, FM is marked, rest are AM
MEDEVAC: FM 32.5000
ANG OPN FM 32.6500
ANG OPN FM 34.5500
ANG OPN FM 40.1500
ARNG OPS PTD FM 41.3000
ARMY OPNS FM 49.9000
RADAR: 138.4000
ARMY OPNS: 149.7000
233.7000
235.7750
Augusta Twr 239.3000
ANG OPS PTD 246.7000
McEintire Twr 253.5000
COLUMBIA TOWER: 257.8000
RADAR: 269.0500
Agusta APP/DEP 270.3000
Augusta APP/DEP 284.6250
COLUMBIA APP/DEP 285.6000
PTD: 298.3000
RADAR: 306.2000
RADAR: 316.4000
Atlanta ARTCC 323.0000
COLUMBIA APP/DEP 338.2000
PMSV: 342.5000
GND CNTRL 348.6000
RADAR: 379.5000
Shaw App 385.6000
And Shaw:
Airport Communications
ATIS: 132.125 270.1
SHAW GROUND: 126.1 275.8
SHAW TOWER: 126.65 254.25
SHAW APPROACH: 125.4 385.6 [1200-0430Z++]
SHAW DEPARTURE: 125.4 385.6 [1200-0430Z++]
CLEARANCE DELIVERY: 121.8 289.4
CLASS C: 125.4 385.6
COMD POST: 318.1 381.3
EMERG: 121.5 243.0
PMSV: 342.5
PTD: 139.6 372.2
RDR: 134.1 294.7X
WX AWOS-3 at SMS (6 nm E): 118.075 (803-469-6750)
WX AWOS-3 at CDN (19 nm N): 119.975 (803-424-1979)
* APCH/DEP SERVICE PROVIDED BY JACKSONVILLE ARTCC ON FREQS 124.7/269.55 (COLUMBIA RCAG) WHEN SHAW APCH CTL CLSD.
jerk
jerkville
Also try this site, looks up to date and very useful
<http://lowcountry-listening-post.blogspot.com/2008/05/charleston-area-milcom-frequencies.html>
lugoffman
Spring Hill, Florida
You did read this in my earlier post? You will not be able to decode the system to hear it. It requires a digital scanner. Period. You will be able to input the 138-144mhz range in AM with the Win97 software. The choppers use a mixture of 40-47mhz in FM, any 118-137mhz is in AM, 225-380mhz in AM. You need to go to Monitoring Times and check out the milcom blog there. I don't understand why they keep moving from the South Carolina forum to here. But, keep asking your questions. It is a lot to learn for someone just getting into milcom listening. Somedays, it is non-stop. Others you can scan for hours and hear absolutely nothing. It is like any other hobby, take it slow, and have fun. I've been listening to milcoms since around 1989. It literally takes years of moniitoring to know where to go and what to program into the radio.
Take it slow and have fun!
Larry
Well everyone tells me i need a digital scanner so the bc296d wont work ??? or will it i thank some one sent me a email saying none of my radios i have in my signature will work what type of digital scanner will work then ?? and you are right I'm having fun now !!
jerk
jerkville
The 296 will work, it will not trunk. And no I didn't read your sig.
But if you program all the 380 MHz frequencies in, you'll be able to listen, but not follow transmissions.
But all the Air frequencies you should be hearing something on them, that and the use of the search key will yield lots of results.
lugoffman
What would be a good radio to use to trunk with than or is there one ?
N8IAA
Fortunately, GA
Sorry, your 296 will trunk the 409mhz system at Fort Jackson. Had to look up that it did 9600baud. Do you have software for the 296? The only thing that the 296 won't do is be upgraded for the rebanding. You need not worry about that. You will be able to follow the Palmetto 800 in SC too.
Larry
jerk
jerkville
The Unidens Portable-396, Mobile-996
and portable-PSR-500 and mobile 600 can
I do know the non-trunking versions of GRE scanner work great or UHF air band.
I have the Pro-2055 and the Pro-164
Read the threads in the scanner forums, all posters have their favorites.
Me I would probably buy a PSR-500 for my next scanner.
My Uniden does trunk track Ft Knox fine.
lugoffman
Larry
Yea i use butell software and scan control both looks like im going to have to break down and get me that psr-500 been wanting one for some time but thought I would not have problems with the bc296d looks like i need about five psr-500 Lol!!!! I wish hahahaha
lugoffman
I ALSO GOT THE 164 looks like im going to have to just play with it fior a while untill i figure out which radio does the best on the air part and might have to just go get me one of those psr-500
Fort Jackson and/or Shaw VHF Trunking P25
I was searching in Camden SC on VHF and found a data TYPE channel on 163.4625 and respective P25 signals on 166.225,165.015,165.190,166.000,165.475 and 163.325... Any Ideas?
