Minitor 3 Voice Pagers
kd6lvp
Sacramento, Ca
I was looking at getting a few Motorola Minitor 3 Voice pagers for my repeater. Does the programmer let you program the pagers into the ham or do you have to hex edit on the UHF band? Or do the funky Control or Shift while entering the frequency. From what I have read you have to hex edit for the VHF side, do you also have to do it for UHF too for something at 440.000 MHz.
NCFire11
Are you talking about programming the Pagers themselves or the repeater system?
DPapay
Morris County, N.J.
You would probably have to hack the software, but keep in mind, pager receivers are not very wideband, so even if you could hack it, the pager may not even work.
kd6lvp
Sacramento, Ca
I can program any tone into the repeater its programming the pager to the frequency,... I think I just got a $50 paper weight...
NCFire11
The pagers are programmed with their own dock and software. You set the channel and tone frequencies with the software.
kd6lvp
Sacramento, Ca
Frequency
I was talking about moving the Minitor Pager frequency to my repeater pair in the ham bands @ 440 MHz
However I don't know which is better to get: E- (453-462) or a Government Band (422-430 MHZ)
Don't see much D model's floating around on E-Bay (450-458)
Also does anyone know which is better to use to move to 440 Mhz between Minitor 3-5's (Yes, I know that 2 will go there with Crystal's but I'm trying to get away from Crystal's) I know you have to HEX the software and I think the software is different between the 3-4's vs 5's???
Thanks,
Mike
