minitor 4 help
jerrylib
I want to recrystal and am having trouble opening the case, Any schematics out there? I have crystals from a older monitor and want to change them to a 4.
Chevyman2011
Franklin
Take out the screw on the bottom of the pager and the pager seperates from top to bottom. Just have to work it a little. It has a seal to make it water ressistant
NCFire11
No need to open the pager at all if you are wishing to change frequencies. You need to take it to a radio shop to get it programmed if you dont know how to DIY.
com501
About 50% of the time we end up breaking at least one of the case clips when taking them apart. You have to be VERY careful, but as another poster stated, this is a programmable pager.
NCFire11
Remove the the allen screw from the bottom and pull on the pager from opposite ends, it should slide about half an inch and then it pulls right apart. You do have to be careful though.
