Minitor classic
setuphelper
I have what I believe is a first generation Minitor and base (1980s?) I believe it actually might work if I knew how to operate the controls. I have no idea what the switches and buttons do. Can someone help? Thanks in advance.
GTR8000
NY/NJ Database Guy
BEE00
On/Off switch on the bottom next to the battery compartment. Volume is the wheel on top. Big aluminum bar on top is squelch. Rocker switch on top changes between alert and monitor modes. Very simple device.
jruta
Nj
You’re probably gonna need new batteries- N cells (2) if memory serves correct? And unfortunately these were not programmable via software.
setuphelper
Thank you for the information- it actually came alive and talked a little this afternoon- it was given to me free along with a charging base with a built in speaker- I’ve got a pretty good idea what it’s programmed to recieve. ..so there is no way to change the program?
jruta
Nj
Very nice. Was actually my first Motorola device back in about 1984ish? No, these are not programmable the way new radios are, assuming it’s in the band you want, it would have to be reworked with crystal and tone reeds. But nice little radio receiver for a single channel.
setuphelper
Good information 👍 thank you for following up, I really appreciate all the help I was at a complete loss on this pager
mc48
Monroe County, NY
I had one of those for the FD. I also worked for a Motorola shop and the most common problem they had was the top switch for tone/monitor would get dirt in them and the contacts would need to be cleaned.
setuphelper
I haven’t had time to clean it yet but I can see where that would be a problem
