Minitor VI as a Scanner?
jhartman
Kirkwood, MO
I was offered a Minitor VI - 5 channel VHF at a great price. I was thinking it would be interesting to play around with and to use to monitor a few local VHF freq. Can it be used in this way?
Thanks!
GTR8000
NY/NJ Database Guy
BEE00
The VI has 8 knob positions. You can set the first one for Scan, and the next five for Monitor F# for each channel programmed. You don't need tones programmed, it will simply operate in carrier squelch.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Thanks!
The VI will only scan two of the five channels.
Tones are not necessary for simple monitoring. But, yes you use it as a simple, two-channel scanner.
GTR8000
NY/NJ Database Guy
BEE00
Ah shoot, you know what...it's been a while since I've programmed one of those and I had forgotten that I believe they restrict each scan list to only 2 frequencies.
GTR8000
NY/NJ Database Guy
BEE00
You could setup a few different 2-channel scan lists. Certainly not ideal, but depending on what you want to listen to at any given time, you might be able to make it work. If you want to scan all 5 channels, you're probably better off spending your money on something else like an analog scanner such as the Uniden BC125AT.
jhartman
Kirkwood, MO
Right. I have one. I just thought the size and battery life was nice.
12dbsinad
It only scans 2 channels because it's intent is a alert receiver. Even scanning 2 channels, Motorola does not guarantee the pager will trip with the associated tone(s). That's why it's called "Probability Scan". But yea, It'll certainly work for a scanner.
12dbsinad
The Minitor VI has Priority Scan. ;)
Yes, and also Silent Scan I believe they call it. I was referencing normal scan as that's what you'd probably want for use as a scanner. Either way, any scan is only 2 channels and not all 5, and there is a reason.
footage
Pacific Rim
It's less sensitive than a scanner but has a great form factor. Great for wx, marine (VTS), etc.
