exkalibur said:Whoever told you that they switched systems is on crack. They're alive and well on the Peel Regional Police system.
I imagine the reason for the newer XTS radios is because that's all that is available these days.
sm3000 said:*lol* yea...PRP is still alive and well I can still hear them...listen to em every night.
I just don't understand the secrecy behind Mississauga Fire to switching systems.
From what I understand, and my source is someone close to MFD, they were running on both systems for a while until they could make sure that this new system was up and running. Now they've completely switched over to the new system, and apparently, cannot be picked up by scanners in Canada. I was told that in order to scan MFD now, you would have to order one in from the States (Whether or not that's true is debateable tho).
MFD was apparently planning this for quite a while and wanted to make sure it was up to snuff.
I guess this is probably the beginning of the end for scanning... if MFD goes off on it's own fancy new system, whats to say PRP isn't going to do the same next? (although I've been told that it's not in the plans for quite a while for PRP, you know that they're most likely going to go this way one day too).
exkalibur said:There's no difference between a scanner bought here and in the US (except some $$$).
The beginning of the end for scanning happened the day scanners were made![]()
Chrome69 said:K here is what i have learned but its not itched in stone... The word is PRP wants to go P25 in the next 2 years and wants the whole Peel System Digital (my guess an hardware upgrade) (some of the guys would know better on here if thats possible or a whole new system would have to be purchased)? Miss Fire and Brampton Fire both like the idea But Caledon is not on the same page. As for the other public services on the system no idea? But what i have learned is whatever PRP wants they usually get it... I would guess when this happens the next step would be for PRP to go encrypted...
Again Mike and them on here would know if and what Upgrades would be required to make that happen. PRP has got encrypted radios now but are having too many problems with them on current system. Any of this make sense?
sm3000 said:You can't decrypt encryption right?
Jay911 said:Short answer: No, you can't.
sm3000 said:Well if they're going encrypted, the only thing left to listen to at that rate would be the buses and the taxis.
