155.37000 | CSQ | KA5824 | Statewide Point-to-Point [Ch 5] | Statewide Common Highway Patrol | Missouri Department of Public Safety | MO |
155.73000 | CSQ | Statewide Sheriff's Net | Law Enforcement Common/Shared | Common/Shared | MO |
Thank you sir.They're both in the DB, carrier-squelch. No tone
155.37000 CSQ KA5824 Statewide Point-to-Point [Ch 5] Statewide Common
Highway PatrolMissouri Department of Public Safety MO
155.73000 CSQ Statewide Sheriff's Net Law Enforcement
Common/SharedCommon/Shared MO
Would the 156.7 work statewide? Im in south west Missouri.Generally they don't use tones on them. The STL County radio does use 156.7 on 155.370 but I think that's so they can mask the audio when it transmits its CW identifier. I know stations calling on point to point don't need any tone to be heard by other monitoring stations.
A lot of departments also use the tri-county Slater system for point to point talkgroup. It's just an analog patch into Slater that sounds like garbage due to it being analog.
I don't recall the last time I heard Sheriff's net on 155.730.
They have a interop talkgroup on Moswin that is probably the replacement for the old Sheriff's net.
I will try it. getting alot of key ups breaking squelch.Statewide NIFOG shows CSQ, I believe.
Yes I know, RR still has sheriffs net listed and so does Sentinelyou're about 20 years too late. They used to be 10 deep! That's well before P25, MOSWIN etc/
Anymore info would help.SInce Sentinal pulls from RR
Audio tones, I was just seeing if the Sheriffs net is still active and the tone for the freq.I'm confused by what you are trying to accomplish? Also what does this thread have to do with audio?
yes, Radio Reference still show the Sheriffs Net active.Generally they don't use tones on them. The STL County radio does use 156.7 on 155.370 but I think that's so they can mask the audio when it transmits its CW identifier. I know stations calling on point to point don't need any tone to be heard by other monitoring stations.
Audio tone is CQS, CCTSS and ect.It should be CSQ. What are you referring to as "audio". I don't think I have heard it used in a long time.
