Mod chip IC-F320s
thesavo
Schenectady, NY
I brought a FOR PARTS F320s unit to use for a Broacastify feeds or as parts for my other one if it was that bad. I took it part to clean it up and found what I would think of as a mod chip for a game console. It is wrapped in shrink tube and I have not cut it part. Has any one see something like this before?
The chip has 5 wires and they seem to have the below listed connections. I still have to take the front cover off to see where two of them go. It just seems to odd.
What are your thoughts?
Mod chip wire colors
blue - cut off opc-617 out of radio
Yellow - To front panel of radio
green - to front panel of radio
Black - X2 Presumed ground
Red - IC9 - Presume 5V
Blue from OPC-617 seems to leave the radio out the normal accessory cable. It would seem by looking at the pinout that the blue wire is intended to Dimmer for the front panel. I would guess that this may be used to control the brightness of front panel or to control glyfs on the display itself.
Update: I did cut off the shrink tube and has there ever been hardware mod to disable Push-to-talk?
it has the following text
PTTDIS R1.0
02/27/02 - 2002 build presumed
The wire colors have the following labels
blue - disable
Yellow - IN
green - Out
Black -Gnd
Red - Vcc
first guess - Dimmer control
second guess - PTT disable
thesavo
Schenectady, NY
2nd guess may be closer. the following two wires go to PTT circuits in the control panel.
Yellow - PTT on the mic pin
Green - Junction of the resistor and Diode on the other side of the PTT
I added an image of the front panel of this radio and another without the modification
I presume that the modification allows the blue wire to trigger PTT allowance. If the blue wire is in the enable state, PTT from the mic jumps from the yellow though the modchip to the green and the circuit works as normal.
Any thoughts?
That would be odd. There's easier ways to disable PTT in the software.
Is there anything on the other side of the small circuit board?
thesavo
Schenectady, NY
Hi mmckenna. Thanks for chiming in.
There are only solder points for the wires on the reverse side.
OK, thanks.
Well, for the PTT function to work like you suggest, the trace would need to be cut somewhere to bypass the normal PTT circuit.
I was thinking it was some sort of radio ID device that triggered when the PTT was pushed, but I'd expect to see a chip on there that would be programmed with the radio ID.
Maybe someone else knows what it is.
a417
can you get better pics of the front and back of that add-on board?
a417
Ya. That's the best I can get with auto focus on my note 10.
Can you try to take the pic the same way you did of the mainboard? If you get too close you will quickly run into the near field of that camera, and it will look blurry. If you back up a couple of inches and not try to fill the screen with the chip you will get a sharper pic that can be blown up better on a screen.
thesavo
Schenectady, NY
@a417 How about this take? I'd say the back has no traces.
It is very difficult to make out what the transistors are labeled.
The last image has the best view of their lids.
OH, I think this might be used to trigger something when the PTT button is pressed, or to remotely disable transmit. Looks like the blue wire would have fed out of the radio to do something when the PTT button was pressed, or interrupted the PTT button, but that would have required a trace to be cut on the circuit board.
Might have been something as simple as muting an AM/FM radio when transmitting, or something that prevented the radio from transmitting when something else was going on.
a417
I agree, I think we are somewhere in that ballpark. Judging by that unpopulated JP2, this appears to be a device that has several roles. Interesting.
thesavo
Schenectady, NY
I think they may have cut the smt resistor on the PTT line on the front panel. . The solder job is rather crude and difficult to photograph.
OK, that makes sense. So this would control the ability of the microphone to activate the transmitter and/or remotely trigger transmit.
thesavo
Schenectady, NY
Thanks for the input everyone. I'm not knowledgeable enough to know if those conditions or outcomes are possible. I'll be using this as a feed radio and will inhibit tx in software. I think clipping the green wire on the radio side will label it as such.
thesavo
Schenectady, NY
I finally got the unit setup to read the config. I checked the entire Radio Reference database for these frequency pairs. I am not sure who was the user prior to the seller on eBay.
ch1 rx 154.505
ch1 tx 159.93
no tone
0 results for this a pair
ch2 RX 152.27
ch2 TX 157.53
tone RX/TX 743n
86 results for this a pair - None found using this Tone
82 In/out match. 4 reverse match
