nexus
With as little as a handheld receiver and a vertical antenna, or a vertical/horizontal polorized yagi you too can monitor communications from the I.S.S.
The worldwide downlink frequency is 145.8000 mHz FM
Ham radio operators all over the world have worked the ISS since it went active. Most two way contacts will require 25 to 100 watts of power and even though a yagi antenna is perfered, contacts have been made on vertical and ground plane antennas. Remember that was just for transmission.
Since you're only going to be receiving I'm sure just an outside antenna would be sufficient. Okay now here is how you find out when they're flying over you. So track them and find out when the next time they will pass over your home and tune in to 145.8000 and listen...
ONLINE REALTIME ISS TRACKING:
http://spaceflight.nasa.gov/realdata/tracking/index.html
ISS's callsign is NA1SS
If you hear any communication on 145.8000 either digital or voice, then rest assured you're intercepting comms from the ISS. Earth stations transmit on 144.4900 for the US and 145.2000 for outside of the US.
more info:
http://spaceflight.nasa.gov/station/reference/radio/
more info:
