Montreal RSP CC Dump
Gh0st99
The tittle say so ... i need an hour or two of RAW control channel dump of the montreal EDACS (rsp) system
i cannot do it myself because i have an untapped 996T and i have no solder notion so i cannot do a discrimator tap myself
i'm curious about encryption and if the radio send the des code in the channel dump (probably in an encrypted way)
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Not sure what you mean by des code?
If you're looking for the actual encryption key then you're out of luck. That is not sent out over the air.
If you're looking for the logical ID of the key, then yes, that is sent out over the air but all that tells the receiving radio is what encryption key to use to decode the transmission. Having the key ID will not help you in any way to decrypt the transmission.
Gh0st99
so if i understand you there is no way we can get the key in the channel RAW dump ? nethier in an encrypted way ?
