Kenwood and CSX....Digital, maybe, but, Yes it is true....
I know this sounds like a beaten dead horse thread, but to set it straight, yes,
all of the FBU's (Florida Business Units) and CSX-PD's have Kenwoods.
(to take it to another level, CSX-PD also has SAT-COMMS being installed that is both VOIP-PTT and INET)
NO, the Engines do not, YES there is a NX-700-CC in production.
JEM Radio
PASTE:
The JEM Radio is based on a 6.25 KHz digital radio with all the form, fit and function of the AAR requirements. You may choose the ICOM F5061D or the Kenwood NX700 radio as the core radio. Both of these radios perform as 25 KHz, 12.5 KHz or 6.25 KHz radios. This clean cab radio (JEM Radio) is designed to function as a one or two piece. To make the JEM Radio into a two-piece radio, the control head is removed from the front of the deck and a blank installed in its place. The control head is inserted onto a remote mounting plate and installed into the standard AAR opening in the locomotive throttle stand. The deck may be mounted under the floor. A data/power cable is routed from a 19-pin connector on the back of the deck to the 19-pin connector on the back of the remote control head. The JEM Radio is then operated normally.
•Reliable Voice Communication
•One-Piece or Two-Piece JEM Radio Configuration
•Programmable Option to Disable 25 KHz in Year 2013
•Programmable HOME Numbers
•Programmable PLL Tones
YES, all yard crew and jobs have Analog AAR channels (according to area)
(yes local radio tech are programing the portables as North, Central, and South areas)
Yes, CSX-PD has a Digital Channel, Talk-Around on AAR 62, and Analog.
Yes, the NX700/800 radio's CAN BE FLASHED OVER TO P25.
Yes, I have a NX-200 with DTMF, (all RR radios are required to have DTMF btw)
The Tampa, Winston, Bone-Valley area is heavily using Kenwood NX-200's.
Yes, CSX is going Narrow band (6.25KHz) by 2Q 2012.
To further the search for information, DPD Productions has posted a list of the NEW
Chl assignments.
DPD Productions - Railroad Frequencies: New 12.5 kHz / 6.25 kHz AAR Radio Plan
From what I have seen, this is what is to come.
NOTE: NXEDGE and DSTAR
D-Star is AMBE, while NXDN/iDAS is AMBE+2. Chip is produced by the same company,
DVS Inc.
DVSI Home Page
and no, the ICOM D-Star's will not decode NXDN/iDAS transmissions.
Icom and Kenwood ARE compatiable in Digital mode however.
YES there is talk about TRUNKING, but not anywhere in the Tampa Bay area at this time.
I have heard that it will be used in Jax Yard, and I can not confirm a chatter that
FEC is going to be using Kenwoods either... if that plays out, NS, FEC, and CSX would
have a trunk system in the Jax area that would be interoprable. (as a test bed)
(i will leave this for the railfan lists on yahoo)
Happy New Year
Evans F. Mitchell
KD4EFM / WQFK-894
Fla. D-Star Tech Support Group
Welcome to the Florida D-Star information website... — Florida D-Star Information
Polk ARES A.E.C.
Polk County, Florida - ARES (Amateur Radio Emergency Service)
BB8330 PIN: 30965B58
