More help with NX-800s
garretcanter
I have two NX-800's
I read the first radio and tried to download it into the second radio.
There were several unsupported features that were unsupported.
Updated the firmware on the second radio.
Second radio just beeps continuously.
Any answers?
Steve
I have two NX-800's
Any answers?
Steve
Firmware/software mismatches can do that. If you have a codeplug from a radio with newer firmware and try to shove it in to a radio with older firmware, you'll get that error.
Beeping continuously can be from many different things.
kd4efm
EL98 Florida
Missing information is what radios you have beside nx800.
Nx800k and dump into a nx800k2 will unlock the vco, and vise versa.
Please update you posting please.
garretcanter
radio one is NX-800 HK -2
radio 2 is NX-800 -K
NX-800HK2 is a 400-470MHz 45 watt radio.
NX-800K is a 450-520MHz 30 watt radio.
You cannot take the file out of one and push it in the other like that and expect it to work. The files need to be for the same submodel radio.
is there different firmware for the NX-800 HK2 and the NX-800-K?
No, they use the same firmware.
The issue you have is they are different sub models and have different frequency splits. It's not going to work trying to push the file out of a radio on a different bandsplit into the others.
garretcanter
Thanks for the help. Being stupid and new to this, I did not notice the different model numbers. The 800-K appears to be toast now that I attempted to put the code-plug from the HK2 unless somebody here has any ideas.
Echo4Thirty
Spring,TX
Generate a new blank K file in KPG and write it in. KPG may complain that its the wrong bandsplit, but write it anyway.
I have an agency with mixed bandsplits and i do this all the time. You can export the K2 file as a .itm and import it into the K. You will have to do things like rename the zones and fix other things, but the channels will come in. Saves a ton of time.
