Greetings,
I’d like to provide two feeds off of the same instance of multi_rx. I already have two dongles, and a single feed already running. What’s required to get the second feed going? In theory I can of course use multi_rx to provide both feeds, but how do I run the output through liquid soap? I am not very well versed in how it works, and would rather just ask for the best practice on how to do this. I’ve looked around and it doesn’t seem to be very well documented, unless I’ve missed something somewhere.
I had thought just running two instances of liquid soap would suffice, but it also seems like that’s a really messy way of doing it, not to mention likely unreliable and complicated to setup that way.
TIA
Current setup is multi_rx running a single feed to broadcastify, using Boatbod’s OP25 (master) Fork, running on an Nvidia Jetson nano. OS is Armbian (Debian) bullseye.
TIA
