rbritton1201
Captain1201
- Joined
- Jul 27, 2020
- Messages
- 407
I recently made a change to programming on a Uniden SDS200, and had to reprogram MSHP Troop C Metro and Rural MOSWIN towers into programming. I programmed the St. Clair and Washington MOSWIN tower sites into programming. But, I inadvertently omitted the Weldon Spring MOSWIN tower site into programming. I suspect I'm no longer receiving Metro transmissions because the Weldon Spring Tower is no longer entered into programming when I inadvertently omitted the Weldon spring MOSWIN tower site from programming. I'm not receiving "Metro" transmissions now, but I'm receiving "Rural" transmissions perfectly.
Am I correct in assuming that I'm not receiving Metro transmissions because the frequencies that the Weldon Spring MOSWIN tower receives are not programmed into the St. Clair and Washington towers? I also realize there is a maximum range that the MOSWIN towers are capable of, and I may be too far to expect reception from some of the MOSWIN Troop C towers that are too far North of where the scanner is based, which is in Union, Missouri. So, if that is correct, which of the towers in the Metro coverage area of Troop C would be advisable for me to add to programming to also receive "METRO" transmissions. I know the Weldon Spring tower reception works well, and it needs to be added back into programming. But, are there other MOSWIN tower sites North of the Weldon Spring MOSWIN tower, that should also be included in programming that are still likely to be received by the scanner when it's located in Franklin County (Union)?
Just trying better understand how the MOSWIN system works, and hope that my assumptions are correct. But, if not, I'm open to further explanation.
