stlouisx50
I have noticed if you program MOSWIN towers in based on the county you will be in, many times does not allow you to hear agencies within a lot of areas of that county. So the best way I have found is to click on every nearby county and see if the range rings cover that County as well. However this too is not always accurate.
Is there an easier method than manually seeing if, "example", 5 counties around you have a tower and coverage that overlaps where you are? I have noticed from my home towers show they cover areas that I have been where you get absolutely no reception as well as areas you get reception, but the coverage map does not show you have coverage.
The last thing I have done is searching for the towers data freq in a search, then looking it up and programing it. But this does not work if you are traveling.
