Motorola Capacity Max Issue
dlm7186
We have a Motorola Capacity Max system - recently started giving error below when syncing changes from our programming workstation.. (We were trying to add another channel) - Local Motorola tech came out and wanted to ship the system off for repairs.
Error: #541 Failed to read CMSS device info
Appreciate it if anyone has any experience with this message.
David Moore
Houston, Texas
Firebuff880
Boynton Beach, FL
I would verify version releases --
An you can look at SA and see if you are logging an Error --
You can certainly call support yourself and talk with a Tech about the issue -- Motorola Custer Support 800-927-2744. In some cases L3 will even work with you to get a remote in connection.
BUT if this were my system, I would take my tech's advise and get the CMSS serviced ASAP. As I bet you have a disk failure developing.
You must have a working CMSS to have a working Cap Max system that's why most systems have a primary & secondary CMSS.
dlm7186
Appreciate your input! We have verified the physical server hardware is OK. We suspect the issue to be with the VMWare host config. Luckily we are able to log into the host and see the VM machines but that's about as far as we've gone. Our local vendor doesn't know anything about CapMax so I'm wasting money having them come out. We will try following up with Motorola.
Firebuff880
Boynton Beach, FL
We have seen issues, specially during updates that were VM related. In all cases the issues were solved by working with Level 3 and in a couple of cases we did give them temporary remote access via a RDP jump host.
Tech21
Motorola has put out patches for VMWare regarding cap max systems. You should get a MOL/MyView account and be able to get the necessary patches and cap max updates as they come out.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
Moto now is performing remote CMSS upgrades due to covid. I am guessing they can help you. Let us know how it goes. TT
IMPRES2
Moto now is performing remote CMSS bricking* due to covid.
A scheduled three hour remote upgrade turned into 6 weeks of back-and-forth remote rebuild sessions to get the TWO bricked servers back to their original 2.8 state before the upgrades could be tried again. The most scary part about their upgrades is the VMWare ESXi host upgrade from 5.5 to 6.5; that’s where one of the servers killed itself.
TampaTyron
Phoenix, AZ
Not uncommon feedback for those scenarios. Imagine customers or other shops trying it on their own? TT
