Motorola Color Coded Portable Radio Antennas
When I got a couple for a couple old Ht1000s to use to monitor they had the /\/\ logo on it. Typically they were ones found on the bay. I usually go direct buying but since it was just to monitor some of our older channels in a office I got them cheap. But I could recall some one saying the aftermarket knock offs could cause issues of you plan to TX. It was some time ago though so Im not too sure what was said.
Dave
W2NJS
Washington DC
The Motorola trademark is regularly faked by the aftermarket people, so it means little or nothing. The source/seller is a more reliable indicator of whether it's genuine Motorola or not.
True, I know they are knock offs and dont plan to TX with them. They serve fine to monitor some analog channels. I only got two and dont plan to buy again. I usually buy direct from a /\/\ dealer. But since the older radios are eventually going to be sold off or retired at the time spending a few bucks was better then buying new hardware for something thats going to be obsolete in time.
n3obl
O AES-1024
PA
at least the apx stuff is marked right on the side of the antenna as to what bands.
Georgia
APX 6000 700/800MHz/GPS antenna is white and measures at 20.2mm
The antenna on my APX 6000 is Black and is for 700/800MHz/GPS. Can I inquire where you got the white on at. I think it would be a bit more visible when inside of a burning structure then a black one even though many times I can't see anyway, it would still be nice to have.
KG4INW
Midlothian, VA
The color codes are in or near the threads at the base of the antenna and aren't actually the color of the antenna overall. Black is the only OEM color available externally.
firefive76
Kansas
Some of the newer antennas are marked right on the base. I just got a new antenna for my HT1250 and it says "Motorola UHF" vertically at the base. Same for my newer XPR6550.
Georgia
Oh....haha....I feel like a dumb-dumb now. I have never taken the antenna off of mine to know that. It would be nice if Motorola would make an antenna in white, or even come up with a way to make a glow-in-the-dark on for firefighter use since it would glow. I have had a few times that I have dropped my radio and it is a little difficult to find a black radio among black char.
KG4INW
Midlothian, VA
Hey, no problem! It is a great idea. They already make some yellow radios, not sure why they don't offer anything else.
wsykes41770
Memphis, TN
Motorola actually makes a few different "safety" colors on some of the newer models and I've seen replacement shells for sell on eBay.
SD70MAC
NC
Does moto have a "whip" style antenna? you are right though. I probably wont use it because I dont want to mess anything up.
We use the Laird EXH155SF for the HT1000,XTS3000 and XTS5000 radios and they are a Whip antenna. They perfom very well and they are rugged as well. They are more flexable than the Motorola wideband antenna which I like alot,having to use my radio for 12 hrs a day. They are not cheap ,but I want them to work. You can buy them from Tessco if you have an account.You can buy them from an Amazon seller which turned out to be Tessco too,even though Tessco is not listed as the seller.
Amazon.com: Laird Techologies 150-160 Portable Antenna, 10.5": Cell Phones & Accessories
The Kenwood antenna is EXH155SFK ,and it will not work on the Motorola SMA.
SABER / MX (paint on end of thread)
470-512mhz Black
anyone have a leigth for this one and will it fit xts series?
KG4INW
Midlothian, VA
I see what you're saying. As far as I've seen, they no longer color code anything but simply write the covered band on the side of the antenna. Still, a reference chart would be nice. Not sure I have time to make one or see if one exits already, apart from what's already available in the catalogs/service manuals. The catalog might be easiest to use as is.
ETA: Yes, nice catalog chart, see page 26 here: APX Accessory Catalog
