Motorola HT1250 Programing Quick Call 2
KD0NDO
I am having a hell of a time programing this. on the channel personality i have under the signaling tab the QCII system that i want and i have it set to OR and when the tones drop the radio does not alert. any help would be greatly appreciated. I am sure they are the right tones
thank you
Martin
K8TEK
Banned
Ohio
thank you
Martin
You set the squelch to "OR"? That means the squelch will open with a valid PL/DPL OR QCII. If you don't want it to alert you need to add another personality. QCII is for alerting, I don't know why you would have a QCII system programmed and activated if you don't want it to alert.
KD0NDO
I want it to alert and it is not alerting. Under the signaling personality there are a lot of settings which do I chose
Sent from my VM670 using Tapatalk
K8TEK
Banned
Ohio
You need to put the tones you want it to activate with in the signaling system. Not the call list tree, the signaling tree. Then select QCII signaling in the personality and select "OR". They are in two separate areas of the CPS.
