Motorola IMPRES Charger Question
M
MITTYCPD
Guest
I recently obtained a WPLN4127 IMPRES display rack charger. It is currently configured to read the displays when used on a desktop. When using the unit hung up the displays are upside down. Does anyone know if the display modules can be flipped so as to be readable when hanging the unit? Thanks in advance. Jim
FuelForFire
The Garden State
To partly answer your question...
On the display module itself there is a little button that flips the display. You would have to take off the cover of the charger and press the button next to each individual display. It seems there should be a simpler way but you never know.
I have never run into an Impres rack charger but I have used the display module. Perhaps some one over at batlabs may be able to answer your question in more detail.
Mike
FuelForFire
The Garden State
After consulting MOL...
DISPLAY TEXT ORIENTATION
In order to allow for desk or wall mounting of the
IMPRES Adaptive Multi-Unit Charger, the CDM is
equipped with the ability to “flip” the
display text 180 degrees.
To do this, insert a large paper clip into the pinhole
below the display perpendicular to the desktop. A
“click” indicates the toggle button has been
actuated, flipping the text 180 degrees.
Grog
Banned
West of Charlotte NC
Sounds like a fun trick to play on someone, flipping some (but not all) of the displays :D
M
MITTYCPD
Guest
Motorola Impres Charger Question
Thanks for the information. I was wondering what those little holes were for but didn't want to go sticking things inside them and blowing something up. It now displays correctly . Thanks again for your help. Jim
