Try this....
Have you ADDED the four channels to the SCAN list?
Do you know how to do that?
On the 1225 you "should" have three buttons on the front showing A B & C. Plus a button with a little "Z" or lightning bolt on it.....
If you press and HOLD the "Z" button, this "should" put you in the programming mode. You use your channel up button to step to the next channel. If you want that channel IN the scan list, press the "A" to add it. The Z will appear on the display to let you know you've added it. If you press "A" a couple of times and watch the display changes, you'll understand what I'm describing....
You follow the same process to REMOVE a freq from the scan list.
To get OUT of the scen program mode, prress "Z" again.....
Again, even IF you have it set up (in the programming to scan) it WON'T until you add the channels.
Also, once you get the channels ADDED, to get it to go to scan, you press the lightning bolt button (the "Z") - don't HOLD it down this time or you'll go back into the program mode and the display will show SCAN for a couple of seconds and then go back to whatever channel you had it on.
You will know it is SCANNING by looking for the little "Z" in the display. The word SCAN does NOT remain on the display.
If you press the scan button again, the "Z" will go away meaning you are NOT in the scan mode now...
This all depends on hoe your programmer set the radio up. On SOME radios you have to follow the process above but use the "A" button to go to the scan program mode. On some programming setups, if you press and hold the "Z" button, it is set up as a nuisance lock-out button....
I hope this helps. Let me know if it does....
Steve/KB8FAR :lol:
AND,
